I am trying to run a 3-phase BLDC motor using FOC, the code is generated and while debugging the code it is showing 0 errors. But later it is showing the following error: Error message from debugger back end: Load failed Failed to execute MI command.
Gaurav Sahu
1 REPLY 1
Gaurav Sahu
The board which I am using is STEVAL-SPIN3202. The error while debugging is mentioned here:
