What does malloc() do in an STM32 MCU run without an OS ?
Shiina
How does STM32 dynamically allocate memory ?
https://stackoverflow.com/questions/77829982/how-does-arm-none-eabi-gcc-9-2-implement-malloc-free
EDIT
You didn't state what compiler you're asking about.
The above relates to the GCC/ARM compiler, as used in the STM32CubeIDE, using the newlib library.
Other compilers & libraries are available; eg,
https://developer.arm.com/documentation/dui0067/d/the-c-and-c---libraries/tailoring-storage-management/support-for-malloc
4 REPLIES 4
EDIT
It allocates memory from the heap. In the GNU/GCC sense this is from the top of the statics to the bottom of the stack via sbrk().
On Keil/IAR it would be a section of heap memory of defined size that the linker places after the statics.
SofLit
From the title I understand: in which situation the dynamic allocation is used if no rtos is used, but in the text I understand something else. Need to be concise.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
thanks
