Incorrect register in LL_UCPD_ReadRxPaySize function
Alexandration
  * @brief  Read the Rx paysize
  * @rmtoll TX_PAYSZ          TXPAYSZ            LL_UCPD_ReadRxPaySize
  * @param  UCPDx UCPD Instance
  * @retval RXPaysize.
__STATIC_INLINE uint32_t LL_UCPD_ReadRxPaySize(UCPD_TypeDef const *const UCPDx)
  return READ_BIT(UCPDx->TX_PAYSZ, UCPD_RX_PAYSZ_RXPAYSZ);
Firmware package: STM32Cube_FW_G4_V.1.5.0
Need to change TX_PAYSZ to RX_PAYSZ
4 REPLIES 4
Amel NASRI
Hi @Alexandration​ ,
Thanks for reporting this issue.
I tracked it internally to be fixed by our development team.
Internal ticket number: 118982 (PS: This is an internal tracking number and is not accessible or usable by customers).
Amel
HFISTM
Hi @Alexandration​
Thank you for reporting this issue.
It has been fixed on our side and is currently being deployed. This update will be available in future releases.
Best regards.
Hi @HFISTM​
Just updated to 1.51 (No release notes describing the diferences in CubeIDE) and a grep reveals that this issue isn't fixed. I have been having trouble to get UCPD to work in G4 wonder if this is the culprit.
Hi @Correa​,
I just checked our tracker, the patch has been postponed to 1.5.2. Sorry about the delay.
If you have trouble making UCPD to work because of something, I advise you to open a new thread in this forum.
Thank you and sorry again for the delay,
Heol
