FatFs impementation _ FR_NO_FILESYSTEM error after f_open
malarab
Senior II
I build an application with FatFs Middleware to log data on a uSD card.
I used the same protocol on FatFs_uSD application with wl55 mcu.
f_mkfs and f_mount function return FR_OK.
but f_open return FR_NO_FILESYSTEM
i tried to change between SDHC and SDSC
i passed the SD module power supply from 3.3V to 5V
i changed min heap and stack sizes
i changed _MAX_SS in ffconh.h
... but always the same problem !
any suggestion please ?
10 REPLIES 10
I should always format the disk to be able to write on it
