DMA and UART not triggering completion INT sometimes
‎2020-04-13 8:20 AM
I'm using serial communication with DMA and sometimes the transmission complete interrupt is not triggered (HAL_UART_TxCpltCallback) the issue happens every few minutes, or every several hundred transmissions.
I saw https://community.st.com/s/question/0D50X00009XkfArSAJ/dmausart-on-stm32f407vg-tc-interrupt-sometimes-not-triggered and I think it may be related: I am putting variable length messages into the DMA and I wonder whether there's constraints in the length that can be set.
I have tested for some time now triying to find a pattern and in all cases the data packet length was pretty small, whenever the DMA stopped triggering the interrupt, the lengths were 17, 11, 5, 5, 3, 5 (6 different tests).
So the questoin is, is there any limitation in the data length to set into the DMA?
For sending, I'm using HAL's HAL_UART_Transmit_DMA()
Best regards.
‎2020-04-13 2:26 PM
The 'F3's DMA does not have FIFO.
There's no particular length limitation for USART/DMA. I believe it's coincidental that you see problems with odd lengths.
‎2020-04-13 9:58 AM
The issue in the linked thread is related to FIFO. Do you use FIFO in DMA? Read out and post the DMA registers' content in case of problematic length.
‎2020-04-13 12:47 PM
I don't know, I'm using the automatic configuration from stm32cubeIDE. I know I'm using the DMA in Normal mode with an increment size of a byte.
I tried browsing for FIFO in the reference manual of my device (stm32f334r8, RM0364) and FIFO was only mentioned along DMA in the SPI section. Is it the same FIFO?
‎2020-04-13 2:26 PM
‎2020-04-14 7:57 AM
Indeed, the interrupt was not triggered because the transfer was not started. The source was a race condition in my code. Thanks for your time.
BR.
‎2020-04-14 12:11 PM
Thanks for coming back with the solution.
