BUG: STM32G474RE Assert issue when TIM17 is configurated as Timebase source
OGhis
With CubeMx 5.3.0 and library version 1.1.0 for the stm32G474RE was the Timebase Source in system (SYS) configured for TIM17
On running the application is the "assert_failed()" executed.
This assert was called from the 'HAL_NVIC_SetPriority() function.
assert_param(IS_NVIC_PREEMPTION_PRIORITY(PreemptPriority));
The PreemptPriority has a value of 0x10 => initialized by __NVIC_PRIO_BITS.
But the "IS_NVIC_PREEMPTION_PRIORITY" macro tell us that the value should be lower than 0x10.
#define IS_NVIC_PREEMPTION_PRIORITY(PRIORITY)  ((PRIORITY) < 0x10U)
What is wrong here the the "IS_NVIC_PREEMPTION_PRIORITY" or the "__NVIC_PRIO_BITS" value
13 REPLIES 13
Amel NASRI
Hello @OGhis​ ,
Please share your .ioc file in order to reproduce the issue you are facing.
-Amel
OPoch
Hello!
I have the same problem for Timebase Source TIM7.
.ioc file below.
Amel NASRI
Hello @OGhis​ and @OPoch​ ,
I reported this bug internally. There is the same problem with STM32Cube examples where HAL_InitTick is redefined to configure a timer as a time base source.
Thanks for highlighting it for us.
-Amel
MMitc
@Amel NASRI​  I am seeing this using TIM1 with FreeRTOS, STMCube Version: 1.1.0 Build: 4551_20191014-1140 (UTC)
Has the correction been released yet?
If not, meanwhile, should I change the priority or remove the assert?
Panometric
@Amel can we get an update on this? Is it still an unresolved bug after 4 months?
Mathieu Massicotte
Same problem here ...
OGhis
See follow link where the issue is produced in the source code:
https://community.st.com/s/question/0D50X0000C6duToSQI/halnvicsetpriority-assert-issue-and-incorrect-preempt-priority-value-for-the-stm32f4-stm32g4-
Please don't remove the assert, otherwise is the priority incorrect configured
Hello @Panometric​ ,
The fix is already deployed internally, but web release of the package may take some time.
You can anticipate changes reporting issues in Github also (https://github.com/STMicroelectronics/STM32CubeG4).
-Amel
OGhis
Not yet resolved in hal lib 1.2.0
