Bug in USB CDC code generator [Solved]
‎2023-03-13 7:39 PM
Hi, today I found an pretty unusual bug while doing some projects with the USB CDC, my code, out of the blue, showed hundreds of errors, after some diggins, me and a friend, found out that in the usbd_def.h, the TypeDef of "USBD_StatusTypeDef" was changed with an "q", I think it must have been some mistake while updating the libraries.
Anyway, just change the letter "q" in the line 209 to "USBD_StatusTypeDef" of the usbd_def.h folder and the errors should disappear.
‎2023-03-15 4:32 AM
Hello @Cde M.1​ ,
Thank you for this clarification.
I made some tests using STM32CubeIDE.1.12.0 version and the STM32Cube_FW_F1_V1.8.0 firmware version and I didn't find any issue.
The "USBD_StatusTypeDef" is well described in line 209.
So, I advise you to download and to use the last firmware version of STM32CubeF1.
Please let me know if the problem is solved.
Kaouthar
‎2023-03-14 4:23 AM
Hello @Cde M.1​ and welcome to the community :smiling_face_with_smiling_eyes:,
Could you please provide more details on the issue:
- Which STM32 product you are using?
- Which STM32CubeMX and STM32CubeIDE versions are you using?
- Which Cube firmware version are you using?
Thank you.
Kaouthar
‎2023-03-14 12:34 PM
Hi @KDJEM.1​ , I am using the STM32F103C8Tx - LQFP48. (BluePill).
The STM32CubeIDE version is the 1.12.0 (But it was appearing in the 1.9, but I updated it and even reinstalled while trying to fix the error).
The firmware I am not 100% sure in wich version it was, but since I updated the CubeIDE and even reinstalled it (with the latest versions), I think it might be the latest.
If you need any more information, feel to free to ask, I will be glad to help.
Thank You.
Carlos E. de Mattia de Sousa
‎2023-03-15 4:32 AM
Hello @Cde M.1​ ,
Kaouthar
‎2024-06-26 11:43 PM
Hi, I am also facing same issue with STM32F070 Controller.
I have already posted the issue in the below link. (I have shared my project also).
FIrmware Version V1.11.5
Kindly help me to resolve this.
‎2024-06-26 11:44 PM
Firmware Version V1.11.5
