ADC multichannel using Interrupt
luke514
I have 3 potentiometers, one on each channel of the ADC, that vary 3V. The ADC reads the values and converts to voltage.
I have not been able by reading the datasheet and looking at some examples online to figure out how to get it to work using interrupts (with DMA it works).
I attach the entire project, can you kindly check it?
Thanks!
12 REPLIES 12
I took the same project I provided to you and changed the sampling time from 480 cycles to 84 cycles and didn't face any issue. I'm still getting the conversion in the live expression:
PS:
I honestly don't know what's going on, I'll attach the project again because I can't figure out the problem.
thanks
