AKhar.5
IEEE-488 (General purpose interface bus / GPIB) implementation
  • April 18, 2023
  • 1 reply
  • 2916 views
I would like to implement IEEE-488. on stm32.
In order to connect send commands and download data from old digital equipment.
Does someone familiar with GPIB library code implementation?
1 reply
Tesla DeLorean
Guru
April 18, 2023
I think there are commercial products that do this.
Perhaps pick a protocol you're familiar with, or you can read/interpret the specification for, as your initial task.
Check GitHub and the wider internet for projects of this nature, on the STM32, and similar MCU, that you might be able to port, or at least get some understanding or perspective from?
Peter BENSCH
...i.e. this implementation for GPIB running on STM32.
Good luck
/Peter
DiBosco
April 8, 2024
Hey Peter,
Am assuming you are the same Peter Bensch I used to work with back in the naughties. If so, hello! :)
I've been looking at this software as I need to implement a GPIB device and documentation is sketchy to say the least. This is some weird code, it has an include file for a PIC and some of the functions it calls don't exist. Do you  know anything about it, or is it just something you found on a Google search?
Cheers!
Rob (from Manchester)
