2024-03-29 07:55 AM
I have 3 potentiometers, one on each channel of the ADC, that vary 3V. The ADC reads the values and converts to voltage.
I have not been able by reading the datasheet and looking at some examples online to figure out how to get it to work using interrupts (with DMA it works).
I attach the entire project, can you kindly check it?
Thanks!
2024-04-05 06:48 AM
I took the same project I provided to you and changed the sampling time from 480 cycles to 84 cycles and didn't face any issue. I'm still getting the conversion in the live expression:
2024-04-08 08:50 AM
2024-04-08 09:07 AM - edited 2024-04-09 09:05 AM
thanks
