USB OTG HS STM32F407 BOARD
‎2024-06-03 6:38 AM - edited ‎2024-06-03 6:39 AM
I have successfully implemented the USB_OTG_FS as host as mass storage class on the STM32F407 discovery board. Now I want to do the same with the USB_OTG_HS
But there is no usb connector available on the discovery board
Can anyone guide me what external components to use and also an example code for the same.
Schematic
ST boards
STM32F4 Series
‎2024-06-03 7:00 AM - edited ‎2024-06-03 7:03 AM
Why ? It will/can do exactly the same as USB_OTG_FS .
Obviously ...so you have to connect a USB socket yourself.
or something like this:
+ just solder the wires to the correct pins !
‎2024-06-03 7:50 AM
You need to use separate hardware for USB HS.
There is a tutorial below.
