2022-12-30 11:39 PM
Which is correct:
BSP files assign PA6 as the LCD_RST line
Schematic assigns PA6 as the LCD_BL control line
BSP files assign PF10 as the LCD_BL line
Schematic assigns PF10 as the LCD_RST line
Which is correct?
2023-01-03 02:44 AM
Hello @Richard Lowe,
For my side, I don't find any contradiction between the BSP file and the Schematic.
PA6 as LCD_BL_CLRL.
PF10 as LCD_RESET.
Could you please share the STM32CubeH7 version are you using?
Thank you,
Kaouthar
2022-12-31 12:30 AM
You will know the answer faster by running the code in a debug cession, then pause it and manually play with GPIO HW registers manually....
2023-01-03 02:44 AM
PA6 as LCD_BL_CLRL.
PF10 as LCD_RESET.
Thank you,
Kaouthar
