STM32H745X-DISCO Documentation - Insert card issue
The schematic and insert card disagree.
The VCP is USART3 PB10/PB11 (verified)
The Arduino header D0/D1 is PB7/PB6 USART1
UM2488 described in the data brief is also missing
https://www.st.com/resource/en/user_manual/DM00547983.pdf
https://www.st.com/resource/en/data_brief/stm32h750b-dk.pdf
13 REPLIES 13
Amel NASRI
Hi @Community member​ ,
I am checking your very first input, it seems to be an error on the user manual and its schematic that was propagated to the flyer of the board.
I'll report this internally to take relevant corrective actions.
Thanks for highlighting it.
-Amel
Hey. Found a flaw with the H745 and CubeMX. You must select the files for the kernel in the Keil Select target window, right-click on the Startup file with the desired suffix, for example, M4, and uncheck the Include in Target Build checkbox in the opened window. Then switch to another kernel and repeat the operation with the same file, only with the suffix M7. After that, the startup conflict error will go away. I will continue to deal with the creation of the project.0690X000009Yx8hQAC.png
The link https://www.st.com/resource/en/user_manual/DM00547983.pdf is working again and UM2488 is available on the web.
