Stm32f429 disc1 board
harry123
Senior
Screenshot (10).pngScreenshot (11).pngThe stm32f429 disc1 board is throwing this error once I connect my board.
The interface firmware FAILED to reset/halt the target MCU.
Check if JP3 is already fitted:
I have a doubt that it is not fitted, therefore the MCU is not powered on.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
3 REPLIES 3
STTwo-32
Hello @harry123
Have you tried to upgrade your firmware?  If so, can you try using a data cable and also try another USB port on your PC.
Best Regards.
STTwo-32
Have you tried to upgrade your firmware? -->No
If so, can you try using a data cable and also try another USB port on your PC?   Yes tried it but there is no change.
PS:
