STLINKv2 vs STLINK /V2 ISOL difference
‎2023-09-14 5:37 AM
hi all,
I am using STLINK/V2 ISOL which says ST_LINK, No MCU device found, just replacing with STLINK/V2 works keep all setup intact.
what could be the reason.
- Labels:
ST-Link
‎2023-09-18 3:00 AM
UM1075, Table 4, Vdd + GND :
‎2023-09-14 6:42 AM - edited ‎2023-09-14 8:40 AM
Hello @prudhvichitturi
Are you sure your STLINK/V2 ISOL is the official ST product ( is an original STLINK). It may be a replica.
Best regards.
II
‎2023-09-14 8:22 AM - edited ‎2023-09-14 8:26 AM
Hello @prudhvichitturi ,
Did you check this user manual : ST-LINK/V2 in-circuit debugger/programmer for STM8 and STM32 - User manual?
Could you please verify your hardware configuration ?
Foued
‎2023-09-14 8:23 AM
The STLINK/V2 ISOL is a ST official product.
Foued
‎2023-09-14 8:50 AM
Hello @Foued_KH and thank you for your feedback.
I'm sure that it is an ST official product. I just mean that the one STLINK that @prudhvichitturi is using maybe a bad cloned copie of the original STLink as in this post.
Best regards.
II
‎2023-09-14 9:09 AM
i bought it from RS , I think it is an official product. I am using stm32L051rz.
It flashes fine with ST-LINK/V2 , but not with ISOL.
‎2023-09-14 9:47 AM
your target is powered ? because st-link isol has no power output , st-linkV2 has power out.
so check voltage on your L05 board, when using st-link isol .
‎2023-09-18 1:52 AM
Ok , that might be the difference, i thought both are the same apart ISOL. i will check it again. could you please point out the power out difference in the datasheet.
‎2023-09-18 3:00 AM
