2024-02-10 10:12 AM
I have a quick question that I couldn't find the answer to.
I accidentally detached ST-LINK part of the NUCLEO-L552ZE-Q board https://www.st.com/en/evaluation-tools/nucleo-l552ze-q.
I would like to reconnect the MCU part with ST-LINK using its SWD CN5 connector, but I couldn't find the pinout of the MCU part. There is no such information in the manual https://www.st.com/resource/en/user_manual/um2581-stm32l5-nucleo144-board-mb1361-stmicroelectronics.pdf.
If it is necessary to solder the board, it is no problem for me, just need the proper SWD pinout.
I can't wait for some hint or someone to show me that I'm just blind and this info is in the manual 🙂
Thanks,
PZdev
2024-02-10 10:32 AM
Hello @PZdev
I suggest you to take a look at the Schematic Pack of the NUCLEO-L552ZE-Q. You will find the necessary informations.
Best Regards.
STTwo-32
2024-02-10 10:32 AM
Hello @PZdev
Best Regards.
STTwo-32
2024-02-10 10:49 AM
Thank you @STTwo-32 🙂
I only checked the Documentation tab on the website, and next to it was CAD Resources.
Either way, my problem is solved.
Best regards,
PZdev
