Ethernet RMII and MII configuration modes
Ramachandran1992
Hi Team,
I am Using NUCLEO-F439ZI EVM, while using ethernet interfacing,
In the RMII mode:
  •  LWIP -> Platform Setting -> Driver_PHY - both LAN8742 and DP83848 are enable.
In the MII mode (both half-duplex and full duplex):
  • LWIP -> Platform Setting -> Driver_PHY - only DP83848 are enable.
My problem was, while using TCP client and server programming, I choose MII mode, I does not show LAN8742. while using RMII mode, the sent from PC -> EVM board, it cannot accept the data. Guide, what is the mistake done? give the clarification.
Thank You
Ramachandran.S
Ramachandran1992
Hi, STea
I selected MII mode instead of RMII mode during ethernet configuration
4 REPLIES 4
STea
Hello @Ramachandran1992 ,
can you please explain what you mean when you said
I don't seem to understand your problem can you please explain what your issue is, is it related to PHYs that you can select in CubeMX? in that case the NUCLEO-F439ZI embeds the PHY lan8742 only.
Hi STea,
The problem was solved by me. the selection of mode was different. thank you for your great help and quick reply.
Ramachandran S
sorry for the late response but can you explain further how you resolved you issue.
when you said "the selection of mode was different" which selection mode you are referring to.
if you can describe how, you did resolve your issue and mark it as solution for visibility purposes.
Ramachandran1992
Hi, STea
