L6470: Run command can be slower than Move command
Options
2015-01-14 12:05 AM
Posted on January 14, 2015 at 09:05
We have noticed that the Run command is able to run slower speed as the Move command, even with a minimal Minspeed. Is that correct/normal or do we have a code error on our side? Thanks y advance, Best regards Ric
Labels:
Motor Control Hardware
1 REPLY 1
Options
2015-04-08 1:05 AM
Posted on April 08, 2015 at 10:05
Hi Ric,
the behavior is correct. The Run command resolution allows reaching lower speed values compared to the positioning commands. The speed of the positioning commands is limited by the MAX_SPEED parameter. Regards Enrico
