EVAL6480H board R1.1 version J6 label problem
cliang
Posted on March 04, 2015 at 15:30
I bought EVAL6480H board which is R1.1 version.
On the board, J6 pin 4 labeled GND, however, if you look at the layout, pin 4 actually tied to VS. I used DMM to measure continuity to verify that GND connects to VS.
Is this a mistake?
#eval6480h-gnd-tied-to-vs
Enrico Poli
Posted on April 08, 2015 at 10:28
I confirm there is an error in the silkscreen of the board.
The labels are flipped compared to the actual connections:
Reagdrs
Enrico
