Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Interrupt Priority Management
Hi ;I am having a confussion on how to set the interrupt priority of a desired peripheral . I am using IAR IDE version 3.11.1 and the MCU is STM8S103F3F6 . I need to know which interrupt table IRQ number I should take account to configure the interr...
BG1 by Senior
  • 1265 Views
  • 0 replies
  • 1 kudos
[BUG] ADC2_ConversionConfig()
Function ADC2_ConversionConfig do three steps:sets ADC result alignenable/disable continuous conversion (there will be problem, unrelated to Continuous mode)writes desired channel into ADC2->CSR (there will be another problem)but if that function is ...
STM8L001 Timer Problem
Hello EveryoneI use STM8L001J3P6 in my project. I want to use timer 3 on compare mode but I dont write any value timer3 register. I write 129 (TIM3_CR1=129;) but register value is zero. Anyone can solve this problem?Thanks.
SCoga.1 by Associate
  • 1011 Views
  • 0 replies
iNQUIRY ABOUT INTELIGENT POWER SWITCH TDE1707BFPT
Hi,This is Raina, working for DENTRO INTERNATIONAL CO., LTD.Our company is subsidiary of HWASUNG G&I Co., Ltd. HS G&I is global leading elevator components manufacturing company located in Changwon, S.Korea.HS G&I is specialized in electronic appara...
APark.2 by Associate
  • 617 Views
  • 0 replies
