Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Reset is not happening while Debug in STVD
Hi,Reset is not happening at only particular project while debugging using STVD. But the same code is working fine if I load the code through STVP. Same MCU Reset is working fine with other project while debugging. I don't know is there any settings...
NM by Associate III
  • 769 Views
  • 0 replies
Resolved! STM8S207RBT6 - write protected
Hello,I have got an industrial PCB with a STM8S207RBT6. I'm able to READ programm memory, data memory and option bytes with ST Visual Programmer and STLink V2.Also I can write data memory and option bytes. But if I try to write program memory I get a...
CNone.1 by Associate
  • 4758 Views
  • 1 kudos
hi guys! i have a discovery stm8s003k board and when i tested a program for cco capability it seems cco will never be stable and program always remain in line : while(CLK_GetFlagStatus(CLK_FLAG_CCORDY) == FALSE); codeand more explain is in detail.
i tested it with below code and ieven change prescalers for lower and higher frequency , i also check it with external crystal (and change the code) but it remains in while(CLK_GetFlagStatus(CLK_FLAG_CCORDY) == FALSE);for ever . when i debug the cod...
akhan.1 by Associate II
  • 787 Views
  • 0 replies
