Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Chip idea
Future time requires minimizing the cost of chemical elements. In addition, robotics is gaining power. Your chips will improve. It will be necessary to reduce the nodes, microcircuits and their functions. The work of microcontrollers in closed contai...
ssm by Associate II
  • 2174 Views
  • 3 replies
  • 1 kudos
M95M04-DR Instruction commands
Page 6 of the datasheet for the M95M04-DR EEPROM has the commands for RDID/RDLS and WRID/LID listed as the same exact commands.Can someone please post the correct command set for this part.
MHami.4 by Associate
  • 1133 Views
  • 1 replies
STEVAL-ISA164v1 not correctly responding
I've got a new STEVAL-ISA164V1 Board.The problem looks like this:When connecting with the ST SMED Configurator there is a warning:The chip on my board is double checked a STNRG388A (well that's what is printed on the chip)I can connect and it looks l...
pbaum.1 by Associate II
  • 1404 Views
Can anyone provide me the spice model of an obsolete (not so obsolete as I purchased it in 2019 December) diode with the model number STPSC1206D?
I even tried to find the model (STPSC1206D) on your new rectifier simulator with the following URL:https://eds.st.com/schottkyferd/Even though as per STM the mentioned part number is obsolete I need the spice model as it is a significant part of my P...
AKuma.39 by Associate
  • 1548 Views
About operating voltage of ST_M24512-r.
We would like to confirm questions below.ST_M24512-r1. Do you have datasheet for information about SCL speed and minimum Vcc? 2. Is our understand correct that the minimum Vcc of ST_M24512-r is 1.8V with our using SCL 400 khz ?      3. Related no.2. ...
TKron.1 by Associate
  • 1381 Views
