Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
ajuda a instalar st visual programer
ola alguem poderia me ajudar estou com dificuldades para instalar o st visual programer.ao tentar instalar ele da falha catastrófica,ja troquei hd,memoria,processador,instalei todos sistemas oparacionais win7,8,8.1,10 e 11 atualizei drivers e coloque...
MARCOS1 by Associate
  • 1234 Views
  • 1 replies
PSD4256G6V-10UI
Part# PSD4256G6V-10UI per data sheet this part thickness should be between 1.350mm and 1.450. We had parts tested that measured only 1.03 and 1.11mmIs it possible that this could normal for the measurement to be out of spec?
Jalle.1 by Associate
  • 829 Views
  • 0 replies
eDesignSuite - Not able to start new design
Hi everyone, am I the only one struggling to star a new design mainly because when trying to do so the software informs me that "this software is not able to build a design suitable for your specification." regardless of the configuration I use it wo...
PVerg.1 by Associate
  • 1075 Views
Hello, I am using the PWD13F60 full bridge driver IC for driving an acoustic transducer. I noticed heavy ringing on the mosfet outputs. I tried suppressing it with bypass capacitors (1nF, 33nF, 100nF) with low success.
Does someone have an idea how I can suppress the ringing and get clean rising edges of the fets? I noticed there is some kind of snubber circuit on the evalboard of the IC, but I cannot find documentation of how it can be used/what values to use. I a...
CGünt.1 by Associate
  • 1116 Views
  • 0 replies
