Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! Inconsistent internal structure and marking for the same part number.Part number: M24C64-WDW6TP
I encountered a problem with inconsistent internal structure and marking for the same part number.We only found a document with such a problem.But it isn't suitable for this time.The document was published in 2014. It only mentions "T" and "K". But ...
EJian.2 by Associate III
  • 4303 Views
  • 5 replies
I'm writing an STM8 assembler using your PM0044 document, but it has errors. For example, BTJF and BTJT are both listed as having an opcode of $72 $0x (the x is the bit mask). Most likely, one of those opcodes is supposed to be $92.
Most likely, the programmer who wrote your assemble used a text document provided by the engineers for his info on the STM8 instruction set. Later on, a technical writer converted that text document into a snazzy PDF for outsiders such as myself. Err...
HughA by Associate
  • 1399 Views
  • 1 replies
Resolved! X-CUBE-GNSS1 only shows minute part of coordinates
I'm using ST's X-CUBE-GNSS1 software pack but it only prints the minute part of my location coordinateCompared with the actual coordinate that shows the degree and seconds partHere's the software pack code that correspond with the above outputvoid GN...
AFidi.1 by Associate II
  • 1503 Views
