STG3692 Supply Voltage
senanurkekec
Hi, I wonder if the analog switch STG3692 can be used with +5V. I have concerns because recommended voltage value is +4.3V in the datasheet while absolute maximum is +5.5V, is there any risks about thermal conditions at that level? What do you suggest?
Thanks for now
senanur
Guru
Follow the recommended operating conditions if you want to ensure proper operation. All datasheets have a similar statement about the "absolute maximum ratings":
