sensor when connected using I2C to ST25R3911B we are seeing any activity
RShiv.1
attached is the code for I2C where we are trying to read from the sensor connected using I2C...I2C_mem_write or I2C_Master Transmit...nothing is sent by the sensor.
any change in the coonfiguration ..kindly let us know.
attached the IOC file also...
Thanks and regards
Ravi chandran
RShiv.1
attached is the sensor data sheet as well
RShiv.1
After adding printf we found I2C_WaitOnTXISFlagUntilTimeout flag is not being set...where could be the issue..kindly let us know
 while (hi2c->XferCount > 0U)
   /* Wait until TXIS flag is set */
   if (I2C_WaitOnTXISFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
    printf("inside while 1 HAL error = %d ",HAL_ERROR);
    return HAL_ERROR;
regards
Ravi
