Getting started with x-nucleo-53l1a1 with nucleo f401re
vishnusf
Hi
I am new to VL53L1X. Can anybody guide me as to how to get started with interfacing vl53l1x with nucleo f401re?
Peter is correct as always, but let's go a little further.
The X-nucleo-53L1A1 when combined with the X-Nucleo-F401RE is called the P-nucleo-53L1A1.
And we have special code for it.
check out:
This bit of code will run on your PC and graphically show what the sensor can do.
Then have a look at the API - It contains a lot of examples that can be compiled with the STM32CubeIDE code development platform.
With all that you should be on your way!!
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
2 REPLIES 2
Peter BENSCH
Take a look at the P-NUCLEO-53L1A1, where exactly this combination is used and where you also find a getting started manual UM2359.
Good luck!
/Peter
check out:
- john
