2024-08-13 3:17 PM - last edited on 2024-08-14 1:23 AM by Peter BENSCH
Hi
I am new to VL53L1X. Can anybody guide me as to how to get started with interfacing vl53l1x with nucleo f401re?
2024-08-14 8:53 AM
Peter is correct as always, but let's go a little further.
The X-nucleo-53L1A1 when combined with the X-Nucleo-F401RE is called the P-nucleo-53L1A1.
And we have special code for it.
check out:
STSW-IMG008 |
Active
Windows Graphical User Interface (GUI) for VL53L1X Nucleo packs. Works with P-NUCLEO-53L1A1 |
Imaging Software | ST |
This bit of code will run on your PC and graphically show what the sensor can do.
Then have a look at the API - It contains a lot of examples that can be compiled with the STM32CubeIDE code development platform.
With all that you should be on your way!!
- john
2024-08-14 1:25 AM
Take a look at the P-NUCLEO-53L1A1, where exactly this combination is used and where you also find a getting started manual UM2359.
Good luck!
/Peter
2024-08-14 8:53 AM
check out:
STSW-IMG008 |
Active
- john
