Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
VL53L4CD getting "stuck" returning the same value
When I run the program, the sensor starts up and is working as expected. Occasionally, the sensor gets "stuck" and just sends the same ranging results. I read that the xshut pin is sensitive and can cause a partial reset of the sensor, putting it in ...
BLiso.1 by Associate II
  • 2573 Views
  • 4 replies
LoRaWAN-End-Node + VL53L4CD, Sleep issue
Hello, I'm using the LoRaWAN-End-Node example on an STM32WL55JC MCU to drive the VL53L4CD sensor.  I would like to use the interrupt pin to get the data from the sensor.what is happening is that once __WFI() in the getting data subroutine is executed...
AElgh by Associate III
  • 1407 Views
Resolved! X-CUBE-TOF1 VL53L3CX_SimpleRanging not working
I'm trying to use the new example available on st.com for VL53L3CX_SimpleRanging (available inside X-CUBE-TOF1) is an example application shows how to make ranging with a satellite board (VL53L3CX-SATEL green) connected directly to STM32F401RE withou...
HElni.1 by Associate II
  • 2027 Views
Can the VL53L5CX work with a non-perpendicular surface?
Hi all, first post here!I'm working on a project that I was planning to use the VL53L5CX sensor where it is installed at about 5/6ft above the floor and pointed down at an angle of around 45°. The goal is to be able to calculate the surface of the f...
DCabl.1 by Associate
  • 2198 Views
  • 3 replies
FoV and Zone Area for VL53L5CX ToF Sensors?
This is my very first post, so hello all! I got a VL53L5CX sensor from SparkFun and I've been playing around with it in the past few days - it seems to be surprisingly accurate and so far has exceeded my expectations.One thing I'm struggling with is...
_legacyfs_online_stmicro_images_0693W00000bjwdOQAQ.png _legacyfs_online_stmicro_images_0693W00000bjwjRQAQ.png
Alix by Associate
  • 2299 Views
  • 1 replies
