Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Resolved! VL53L4CD Driver Questions
I am using the VL53L4CD sensor board very similar to https://www.sparkfun.com/products/18993 with my application. I am using the modified version of https://github.com/stm32duino/VL53L4CD driver on the Raspberry Pico board. I am using the both the xs...
Resolved! VL53L4CX Latency
Hi,I am conducting a rapid object detection test using the VL53L4CX sensor. I am moving an object towards the sensor at approximately 5 km/h and aiming to light an LED if the object is detected at around 60 cm to measure the sensor's response time. H...
Resolved! VL53L5CX address configuration added to linux driver fork
Hi. I've amended the linux driver for the VL53L5CX with better support for multi-sensor installations, with the I2C address set by the kernel module at initialization, address given by the device tree. ST feel free to add to the official driver, as t...
Poleshift by Associate II
  • 1685 Views
  • 1 replies
Vl53L8CX with STM32WB5mm-DK
I am using Vl53l8cx with stm32wb5mmdk.  I am unable to initialize the sensor via this board. I used  it with a nucleo board and it worked fine, but I need a BLE-based controller to share data. SDA  and SCL are pulled up with 4.7k 3v3 is connected to ...
Rituraj by Senior
  • 1121 Views
  • 1 replies
