Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
I get the same histogram data every time on VL53l3cx
As shown below, the first line is the distance and the rest are histogram data whci I think is same and not correct?103-4652409,-2097499426,1344930034,1327221713,525211626,33064954,-17059034,235676156,1093868795,138478570,-1947005701,2044266306,-9799...
DMehr.2 by Associate II
  • 1253 Views
Where can I find the i2c registers for the VL53L3CX? I am trying to implement this in a design with an FPGA, but I cannot find any information regarding the registers in the datasheet.
Where can I find the i2c registers for the VL53L3CX? I am trying to implement this in a design with an FPGA, but I cannot find any information regarding the registers in the datasheet.We are looking at simply taking a range measurement every time the...
PFlet.1 by Associate
  • 991 Views
  • 1 replies
How to use VL53L3CX with STM32WLE5JC ??!
I own a small dev board (LoRa-E5 mini from SeeedStudio) and coding using STM32cube IDE + MX.I have made project from scratch, using LED, switch, UART (works fine !)... and now I want to use my VL53L3CX-SATEL board.The board is defined on I2C2, all lo...
SC26 by Associate II
  • 2745 Views
  • 6 replies
VL53L5CX Register description
I just started working with VL53L5CX but can't find details on the commands/registers. I had a look to the example code and can use it but I can only guess what the different settings send via i2c to the firmware will do. I also studied the different...
PBoer.1 by Associate II
  • 2246 Views
  • 3 replies
I use sensor VL53L1CBV0FY/1. It works, distance is measured. I began to make calibrations and problem occured. After calling VL53L1_PerformRefSpadManagement the error -13 (VL53L1_ERROR_CONTROL_INTERFACE) is appeared.
Inside this function I determined that the error is in inner function VL53L1_run_device_test. I can not find information about it. The PCB is wired correctly. There are interface pull-ups. Thanks.
IShir.1 by Associate
  • 931 Views
  • 1 replies
