waclawek.jan
Don't litter posts with whitespace (empty paragraphs inserted around code blocks)
  • July 15, 2023
  • 14 replies
  • 14727 views
    Best answer by Lina_DABASINSKAITE
    Dear @waclawek.jan , all,
    It's been a while since we updated on this topic, but finally I can get back with good news!
    The fix of this behavior is now completed and no more white spacing should appear around the code blocks.
    Feel free to test it on your end and let me know if you still face it.
    I apologize for it taking so long to be fixed and the inconveniences you faced in this time.
    Lina
    Lina_DABASINSKAITE
    ST Community Manager
    July 20, 2023
    Hello @waclawek.jan ,
    Thanks for letting me know. I am looking into it why UI is set this way. Will keep you posted once I will have an answer.
    I am sorry about the experience.
    BR,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    waclawek.jan
    This problem gets more and more aggravated if one edits his own posts several times, as each time the post is saved more and more space is added.
    August 21, 2023
    Hi @waclawek.jan,
    just to update you that we've reported this issue as a bug. Thank you for your continued participation and feedback.
    Best,
    Adam
    waclawek.jan
    Test
    some code, there was no extra newline around it in the initial post
    ... and the edit added them.
    So, this bug report was clearly ignored by Khoros.
    @unknown
    @Lina_DABASINSKAITE
    @Laurids_PETERSEN
    Tesla DeLorean
    Guru
    November 28, 2023
    Still broken, still compounded with editing..
    Tobe
    Senior III
    April 18, 2024
    When i edit my post, quite a few newlines are introduced before and after my code snippets
    That needs a fix ASAP, because its really bad.
    Tesla DeLorean
    Guru
    April 18, 2024
    Yes, I think Jan and I have reported it before too.
    Nothing in Khoros gets fixed..
    Peter BENSCH
    Yes, there are still things to be fixed in the community, but I can't let the statement "nothing gets fixed" go unchallenged.
    I've also been annoyed by the problem of extra blank lines before and after code blocks, but until the fix comes you can work around it by editing manually after switching to HTML. I've just forgotten exactly how I did it, but I'll be happy to look at it again if necessary.
    /Peter
    @Lina_DABASINSKAITE
    @Laurids_PETERSEN
    BarryWhit
    Lead
    July 1, 2024
    I just reported this elsewhere, and andrew pointed me here.
    Very annoying, please fix ASAP.
    "- If someone's post helped resolve your issue, please thank them by clicking ""Accept as Solution"".- Please post an update with details once you've solved your issue. Your experience may help others."
    Tesla DeLorean
    Guru
    July 1, 2024
    Yes, it's been a gripe for a while. Along with the spurious HTML error report/warning when pasting something into the editor and posting. That seems to self remediate if we're persistent and push to post again.
    Usually I catch this as I paste something in, and it's evident it's in a box with odd formatting it brought with it. Ctrl-Z and paste as plain text..
    BarryWhit
    Lead
    July 1, 2024
    I don't suppose ST is using an open-source solution for this forum....? [he asks, knowing it was futile]
    Tesla DeLorean
    Guru
    July 1, 2024
    No, they've all been commercial, was Microsoft SharePoint, then Jive, then SalesForce, now Khoros.
    I guess one of the selling points being Corporate and "supported" by paid engineering staff rather than a couple of guys around their kitchen table, although I think the latter could be motivated by much smaller sums of money to fix / add things, or get them right the first go around.
    Other scenes I participated on frequently had the databases self-immolate, requiring a recovery/rebuild, but they weren't paying Oracle prices. That said they had a lot better grasp of how the BBS and Forum mechanics were supposed to work.
    BarryWhit
    Lead
    July 1, 2024
    a new reality! wouldn't that be awesome. I can't wait to be deployed, managed and scaled. Sign me right up.
    Andrew Neil
    The issue continues to annoy.
    And now, possibly another manifestation of the bug same:
    https://community.st.com/t5/feedback-forum/more-spurious-whitespace-in-posts/m-p/719528
    Tesla DeLorean
    Guru
    September 12, 2024
    And the SHIFT-SHIFT-EIGHT / GT-GT-EIGHT breaking things, I reported elsewhere, impacts both source code block panes, and primary post texts.
    Honestly we don't need to be breaking stuff to support f***ing emoji's !!
    Tesla DeLorean
    Guru
    October 12, 2024
    15 MONTHS on this is STILL BROKEN
    Andrew Neil
    Example:
    https://community.st.com/t5/stm32cubeide-mcus/debugging-stm32f429-on-disco-board-with-cubeide/m-p/719506/highlight/true#M30610
    If I edit the post, the whitespace does not appear in the editor!
    Using the HTML source view, it can be seen:
    Manually removing all those <p>&nbsp;</p> does seem to fix it.
    Could this be another manifestation of the same bug which underlies this issue:
    https://community.st.com/t5/feedback-forum/don-t-litter-posts-with-whitespace-empty-paragraphs-inserted/m-p/574693
    Reply migrated from another topic.
    :thinking_face:
    Laurids_PETERSEN
    September 12, 2024
    Hi @Andrew Neil
    We have been investigating this issue for some time and indeed the <p>&nbsp;</p> in the HTML code seems to add itself in.
    It can be "hot-fixed" by adding a <div> (text) </div> between the text. This also applies to code blocks that are facing issues. We are still researching a complete fix, so I cannot give you a time frame at this point.
    Best regards,
    Laurids
    Tobe
    Senior III
    October 29, 2024
    After editing the following post, there are newlines added:
    https://community.st.com/t5/stm32-mcus-products/my-micros-function-is-not-glitchfree/td-p/736780
    They get added on every edit.
    waclawek.jan
    Thanks for reporting this, but ST already knows.
