waclawek.jan
Don't litter posts with whitespace (empty paragraphs inserted around code blocks)
    Lina_DABASINSKAITE
    ST Community Manager
    March 20, 2025
    Dear @waclawek.jan , all,
    It's been a while since we updated on this topic, but finally I can get back with good news!
    The fix of this behavior is now completed and no more white spacing should appear around the code blocks.
    Feel free to test it on your end and let me know if you still face it.
    I apologize for it taking so long to be fixed and the inconveniences you faced in this time.
    Regards,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    Andrew Neil
    Tobe
    Senior III
    February 10, 2025
    It is still annoying...
    WHEN will it be fixed?
    It cant be that difficult. Its just text and some html elements!!!
    Lina_DABASINSKAITE
    March 20, 2025
    Regards,
    Lina
    Andrew Neil
    OK - here's some code:
    int main( void )
     printf( "Hello, code editor!\n" );
    there was some code.
    Edited the post
    Andrew Neil
    @Lina_DABASINSKAITE indeed, that seems to have worked!
    Created a post:
    Posted:
    Edited the post:
    Posted the edit:
    No spurious blank lines!
    unsigned_char_array
    Lead III
    March 20, 2025
    It seems like in addition to no new whitespace being added to new posts existing posts have been fixed too. They all look nice without extra whitespace.
    "Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
