Don't litter posts with whitespace (empty paragraphs inserted around code blocks)
24 REPLIES 24
Lina_DABASINSKAITE
Community manager
Community manager
Hello @waclawek.jan ,
Thanks for letting me know. I am looking into it why UI is set this way. Will keep you posted once I will have an answer.
I am sorry about the experience.
BR,
Lina
This problem gets more and more aggravated if one edits his own posts several times, as each time the post is saved more and more space is added.
Hi @waclawek.jan,
just to update you that we've reported this issue as a bug. Thank you for your continued participation and feedback.
Best,
Adam
Test
some code, there was no extra newline around it in the initial post
... and the edit added them.
So, this bug report was clearly ignored by Khoros.
@Community Assistance Team
@Lina_DABASINSKAITE
@Laurids_PETERSEN
Still broken, still compounded with editing..
Tobe
Senior III
When i edit my post, quite a few newlines are introduced before and after my code snippets
That needs a fix ASAP, because its really bad.
Yes, I think Jan and I have reported it before too.
Nothing in Khoros gets fixed..
Yes, there are still things to be fixed in the community, but I can't let the statement "nothing gets fixed" go unchallenged.
I've also been annoyed by the problem of extra blank lines before and after code blocks, but until the fix comes you can work around it by editing manually after switching to HTML. I've just forgotten exactly how I did it, but I'll be happy to look at it again if necessary.
/Peter
@Lina_DABASINSKAITE
@Laurids_PETERSEN
You'll note who's doorstep I placed blame, and it's not ST's.
There are issues here since inception that have still not been remediated. As any kind of bug list and progress reporting on addressing, prioritizing and fixing is entirely opaque, it's hard to discern progress from the outside beyond the rearranging of icons and size of edit boxes.
The Jive team still seemed a lot more responsive to material functionality issues, well until the acquisition, and they killed the flagship product, and lost the plot of "As A Service"
