Don't litter posts with whitespace (empty paragraphs inserted around code blocks)
24 REPLIES 24
Hi @Andrew Neil
We have been investigating this issue for some time and indeed the <p>&nbsp;</p> in the HTML code seems to add itself in.
It can be "hot-fixed" by adding a <div> (text) </div> between the text. This also applies to code blocks that are facing issues. We are still researching a complete fix, so I cannot give you a time frame at this point.
Best regards,
Laurids
And the SHIFT-SHIFT-EIGHT / GT-GT-EIGHT breaking things, I reported elsewhere, impacts both source code block panes, and primary post texts.
Honestly we don't need to be breaking stuff to support f***ing emoji's !!
15 MONTHS on this is STILL BROKEN
Tobe
Senior III
It is still annoying...
WHEN will it be fixed?
It cant be that difficult. Its just text and some html elements!!!
