Don't litter posts with whitespace (empty paragraphs inserted around code blocks)
waclawek.jan
32 REPLIES 32
Hi @Andrew Neil
We have been investigating this issue for some time and indeed the <p>&nbsp;</p> in the HTML code seems to add itself in.
It can be "hot-fixed" by adding a <div> (text) </div> between the text. This also applies to code blocks that are facing issues. We are still researching a complete fix, so I cannot give you a time frame at this point.
Best regards,
Laurids
And the SHIFT-SHIFT-EIGHT / GT-GT-EIGHT breaking things, I reported elsewhere, impacts both source code block panes, and primary post texts.
Honestly we don't need to be breaking stuff to support f***ing emoji's !!
15 MONTHS on this is STILL BROKEN
Tobe
Senior III
After editing the following post, there are newlines added:
https://community.st.com/t5/stm32-mcus-products/my-micros-function-is-not-glitchfree/td-p/736780
They get added on every edit.
Thanks for reporting this, but ST already knows.
Andrew Neil
Cross-ref:
https://community.st.com/t5/feedback-forum/post-edit-adds-newlines-like-crazy/td-p/736784
Indeed - a long-known issue.
Can be somewhat mitigated:
https://community.st.com/t5/feedback-forum/don-t-litter-posts-with-whitespace-empty-paragraphs-inserted/m-p/668939/highlight/true#M1347
Tobe
Senior III
It is still annoying...
WHEN will it be fixed?
It cant be that difficult. Its just text and some html elements!!!
Lina_DABASINSKAITE
Community manager
Dear @waclawek.jan , all,
It's been a while since we updated on this topic, but finally I can get back with good news!
The fix of this behavior is now completed and no more white spacing should appear around the code blocks.
Feel free to test it on your end and let me know if you still face it.
I apologize for it taking so long to be fixed and the inconveniences you faced in this time.
Lina
OK - here's some code:
int main( void )
   printf( "Hello, code editor!\n" );
there was some code.
Edited the post
Announcement
