Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! Enabling lockstep core in SPC570S MCU
Hi,I am prototyping on a SPC570S-DISP development board, and I am trying to enable the checker core in the MCU. I read the technical reference manual, and it has stated that the checker core can be enabled from the UTEST DCF memory registers. How ca...
NBula.1 by Associate III
  • 2969 Views
Write access to memory range refused
Tried to flash SPC560B50L5 MCU with example program "SPC560BCxx_RLA PWM-ICU Test Application" UDE STK returns write access to memory range is refused. Loaded Bootloader program in ude stk , then flashed pwm program to mcu it gets programed.But every ...
$AK by Associate III
  • 1429 Views
  • 1 replies
Resolved! SPC5studio build warining analysis configuration don't take effect.
I use SPC5studio to build code, there are some configurations of warning I want to reset, but it don't take effect. The configuration of path is my_project-->Properities-->C/C++ General-->Code Analysis-->Use project settings. I wonder wether is it ri...
Ljich.1 by Associate
  • 1201 Views
  • 1 replies
Resolved! Non-intrusif scanf()
Hello,I'm working on the SPC574S-DISP board, I've set up FreeRTOS and I would like to have a way to do a non-intrusive scanf.I would like the program to keep running and wait for a key to be pressed to access a submenu.The problem is that with scanf(...
Bastien1 by Associate III
  • 1910 Views
  • 3 replies
Resolved! PWM with DMA in SPC560B54L5 MCU
I have used PWM in SPC560 MCU and in addition to that DMA is required for ws2811 addressable led.how to use pwm with DMA.Thanks in AdvanceRegards,AK
  • 1257 Views
Resolved! RX interrupt with Runtime-IO
Hello, I would like to know if it possible to make RX interrupt with the serial driver initialize thanks to Runtime-IO Component RLA ?In reality, I want to use scanf() with interrupt to make it non-blocking.Thank you by advanceRespectfully Bastien
  • 1653 Views
  • 1 replies
