AutoDevKit Ecosystem
Ask questions and find answers on the AutoDevKit solution. Discuss voltage configurations, motor control, and AutoDevKitStudio programming.
Resolved! Automotive Motor Control using SPC560
Dear all,Currently, I'm trying to test the SPC560P50L3 MCU for a Motor Control application. I know that I can do it easily by clicking on "import samples from application library". However, every time I try to create the project manually by adding th...
Agga by Associate II
  • 3247 Views
  • 1 replies
  • 1 kudos
Resolved! BMS63EN Diagnostics - How to?
I had a fine working setup with BMS63 for some hours. Than cell 12 showed 0V and the fault light in the ISO SPI came up. A short measurement showed, the cell was indeed empty (I am testing with very old cells). After replacing the cell cell 12 still ...
Orbiter by Senior
  • 18933 Views
  • 22 replies
  • 1 kudos
Resolved! Error when execute make all in WSL environment
Hi, I am working on a project generated from AutoDevKitStudio-2.2.1, with few SPC58ECxx applications. Able to generate, build and run using the AutoDevKitStudio, and Makefile is auto generated in the project folder.I am using DiscoveryPlus developmen...
Adam_J_2-1751333975224.png Adam_J_1-1751333844010.png Adam_J_3-1751334200828.png
Adam_J by Associate
  • 2172 Views
  • 1 replies
  • 1 kudos
Resolved! Debugging SPC56 with AEK-MCU-SPC5LNKU
I recently bought the STEVAL-TTM002V1 along with the AEK-MCU-SPC5LNKU debugger since it was mentioned support for SPC56 would be available before 2024. However, I haven't been able to get the AEK-MCU-SPC5LNKU debugger to work with the SPC56.I'm wonde...
Uk07 by Associate
  • 3392 Views
  • 8 replies
  • 3 kudos
Resolved! Switch S3 SPC56EL70DL5
Hello, what does these switchs do? It has something to do with the jtag? (The ones that are right up the botton aside of the jtag)Ty
Agustin by Associate II
  • 665 Views
  • 1 replies
Resolved! issue in disassembly view
Hi Team, We are facing issue in debugging like dissambly view is not showing correct flow even though we clean build the ws. code:  disassembly view:Tried methods:- changed workspace- clean and rebuild- changed HW- changed machineLet me know how it c...
Resolved! Error when extracting en.stsw-autodevkit.zip file
Good morning everyone On the https://www.st.com/en/embedded-software/stsw-autodevkit.html, the en.stsw-autodevkit.zip file is not opened properly. I tried winrar and 7zip file manager, but it results in an error when opening the compressed file. How ...
antart by Associate
  • 2399 Views
  • 5 replies
  • 1 kudos
