Error when extracting en.stsw-autodevkit.zip file
  • May 27, 2025
  • 870 views
Good morning everyone On the https://www.st.com/en/embedded-software/stsw-autodevkit.html, the en.stsw-autodevkit.zip file is not opened properly. I tried winrar and 7zip file manager, but it results in an error when opening the compressed file. How can you help me? I didn't even find a previous version downloadable to buffer. Thank you.
Best answer by Max VIZZINI
It should be fixed!
Max VIZZINI
If you check in your error message it seems that file original dimension is 0.
Double check that you are able to download the entire file (1.7GBytes)...
It could happen that download reset because the file is quite big.
Best Regards,
AutoDevKit Team
antartAuthor
Hi Max,
I've already checked the dimension of the file, is 1.8GB. Seems that the mirror link is corrupted, I've tried to download even in Japan language.
Max VIZZINI
I have confirmed there is a glitch in the download site, the download should be 1.9Gigabytes.
We are working to solve it.
Best Regards,
AutoDevKit Team
