STM32CubeProgrammer c++ api qt compiling for raspberry os (debian based)
JCuna.1
STM32CubeProgrammer has a C++ API which allow to create program compiled using qt creator. Is it possible to compile for linux os and run in rasperry os which is debian based?
Sara BEN HADJ YAHYA
Hello @Community member​ ,
Thanks for your feedback,
Unfortunately STM32CubeProgrammer is not supported on ARM devices and the C++ API cannot be used because it needs DLLs that are compiled on intel x86.
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
1 REPLY 1
Sara BEN HADJ YAHYA
Sara.
