2023-05-31 11:46 PM - edited 2023-11-20 04:15 AM
I used to work with Nucleo board STM32G474 and programm them. Recently I can not open the file to programm my devices. I looks a window problem.
I installed again all the ST Tools but the problem remain.
I can not open files.
2025-02-13 05:46 AM
I'd figure out why I encountered the issue, and I solved it by followed reference:
2023-06-01 12:06 AM
Hi @AMart.33 ,
Sorry to hear that, please help me to understand.
Do you have a error message or something?
Did you try to update the software version?
Best regards,
A.MVE
2023-06-01 12:16 AM
No I do not have any error, I can not open any files, the window does not open.
Yes I have the latest software version.
2023-06-01 01:15 AM
Are you on Windows, Linux or MacOS?
You should know that there is no need to install any Java™ SE Run Time Environment since version 2.6.0. The STM32CubeProgrammer runs with a bundled JRE available within the downloaded package, and no longer with the one installed on your machine. The bundled JRE is Liberica 8.0.265.
I suppose that you already tried to restart/turn off your computer.
Aime
2023-06-01 04:14 AM
Yes, I am on Windows, I tried to restart/ turn off the Laptop and I also unistall the software and install it again. nothing changed. The software worked till mid of last week and then I hat the issue that I can not open any files.
2025-02-13 05:24 AM
I encountered the same issue. Has this problem been resolved? (My system is Windows 10, and the software is 2.18.0.)
2025-02-13 05:46 AM
