2024-02-20 05:40 AM
I have just purchased a STM32H573I-DK Discovery board, only to find it doesn't appear to recognise the ST-link V3. Is this a true problem, or just me, and is there a solution?
2024-03-28 06:15 AM
Internal tracking number for this issue is 175551
Aziz
2024-02-20 05:52 PM
Try another host machine known to Just Work (a.k.a. Windows). Will it detect the ST-LINK? If not, check the jumpers, USB cable, power supply etc.
2024-02-21 08:39 AM
I tried it on a Windows machine and it works fine - looks like it is an issue for MAC users. It is recognised by the "system" so look like it has got the driver, but CubePeogrammer doesn't recognise it.
2024-03-19 12:51 AM
2024-03-28 05:30 AM
The hub solution seems to work ok - thank you. Do you know when ST will provide Apple silicon support, so this workaround is not needed?
2024-03-28 06:15 AM
Aziz
2024-06-03 04:39 PM
Hi @Aziz BRIGUI @Maryem any new developments on this or is using the hub in the middle the only solution for now?
We are building a new platform for a University course and would like to avoid having to give out hubs to students.
2024-07-05 06:43 AM
Hi Aziz, are there any updates on this issue for ST-link V3 on apple silicon?
2024-07-05 06:55 AM
Unfortunately, there are no updates on this issue at the moment. We will keep you informed as soon as there is any progress. Thank you for your understanding.
Maryem.
