ST-LINK_CLI.exe no full support for STM32G43x?
‎2021-05-21 2:02 AM
I was trying to set option bytes (BOR) with the ST-Link CLI (v3.6.0.0) for STM32G431, but it prompts that this feature is not available. With the ST-LINK Utility (v4.6.0.0) it is possible to set the BOR Level.
I guess the ST-Link CLI is no longer maintained and you have to switch to the new one (Cube Programmer CLI), is that correct?
Thank you for your information!
- Labels:
STM32CubeProgrammer
STM32G4 Series
‎2021-05-21 4:57 AM
Correct, the ST-LINK Utility is on status NRND (Not Recommended for New Designs) and should be replaced by the STM32CubeProgrammer (see a similar question here).
Good luck!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
‎2021-05-21 4:57 AM
Good luck!
/Peter
‎2021-05-21 5:01 AM
Thank you very much for your answer!
