It seems that erasing selected sectors does not work with B-U585I-IOT02A. If I read back flash, it is not 0xff filled. Full chip erase is OK. Is this known issue ?
‎2022-03-04 5:53 AM
‎2022-03-11 4:43 AM
I found that I had SWAP_BANK set at option bytes. After I cleared that bit, selected sectors were erased. So, this was my mistake, CubeProgrammer is OK.
‎2022-03-09 1:52 AM
I tried latest CubeProgrammer (2.10.0) and it did not work either. I had version 2.9.0 earlier. Logs:
11:31:09:200 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:09:200 : r ap 0 @0x0BF99EFE 0x00000004 bytes Data 0x00880092
11:31:09:212 : Flash sector erase ...
11:31:09:212 : Flash erase...
11:31:09:213 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:09:214 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:09:214 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00000001
11:31:09:215 : r ap 0 @0x46020800 0x00000004 bytes Data 0x00000000
11:31:09:215 : w ap 0 @0x46020800 0x00000004 bytes Data 0x00000200
11:31:09:217 : w ap 0 @0x46020800 0x00000004 bytes Data 0x00000000
11:31:09:217 : r ap 0 @0x40030400 0x00000004 bytes Data 0x00000004
11:31:09:219 : w ap 0 @0x40030400 0x00000004 bytes Data 0x00000004
11:31:09:222 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000018
11:31:09:223 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000018
11:31:09:225 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43000018
11:31:09:226 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00000001
11:31:09:234 : w ap 0 @0x40022020 0x00000004 bytes Data 0x000000FB
11:31:09:235 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00000000
11:31:09:237 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000018
11:31:09:237 : w ap 0 @0x40022028 0x00000004 bytes Data 0x4300001A
11:31:09:239 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:09:240 : r ap 0 @0x40022028 0x00000004 bytes Data 0x4300001A
11:31:09:240 : w ap 0 @0x40022028 0x00000004 bytes Data 0x4300001A
11:31:09:241 : r ap 0 @0x40022028 0x00000004 bytes Data 0x4300001A
11:31:09:241 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43000002
11:31:09:241 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000002
11:31:09:242 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43000002
11:31:09:243 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000002
11:31:09:243 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43010002
11:31:09:244 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00010000
11:31:09:245 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00010000
11:31:09:246 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00000001
11:31:09:246 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000002
11:31:09:246 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43000000
11:31:09:247 : r ap 0 @0x40022028 0x00000004 bytes Data 0x43000000
11:31:09:247 : w ap 0 @0x40022028 0x00000004 bytes Data 0x43000000
11:31:09:248 : r ap 0 @0x40022020 0x00000004 bytes Data 0x00000001
11:31:09:248 : Existing specified sectors are erased successfully Protected sectors are not erased
11:31:09:270 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:09:270 : r ap 0 @0x0BF99EFE 0x00000004 bytes Data 0x00880092
11:31:10:231 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:10:239 : r ap 0 @0x0BF99EFE 0x00000004 bytes Data 0x00880092
11:31:11:249 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
11:31:11:256 : r ap 0 @0x0BF99EFE 0x00000004 bytes Data 0x00880092
11:31:12:281 : r ap 0 @0x40022040 0x00000004 bytes Data 0x1CFFF8AA
‎2022-03-11 4:43 AM
‎2022-03-11 4:57 AM
Thanks @JR.3​ for sharing the status and the root cause of your issue.
Glad to know that it is fixed.
-Amel
