Is it possible to change location of Data_Base directory?
2022-10-05 1:19 AM
I'm writing a C# version of the USB_Example program. You can set the loader path using the setLoadersPath call, but the path of the Data_Base directory seems to be fixed to "/../Data_Base/<whatever you are trying to connect to>.html. Is there any way of changing this path too? I'm using the latest 2.11 API
STM32CubeProgrammer
USB
2022-10-06 8:52 AM
Hello @MSSloan1962,
Thank you for posting,
Unfortunately for now, there's no way to modify the Data_Base path. However, the feature is now requested from STM32CubeProgrammer development team.
Internal ticket number: 98648 (This is an internal tracking number and is not accessible or usable by customers)
I will keep you posted with updates.
Aziz
2022-10-06 8:52 AM
Hello @MSSloan1962,
Aziz
2022-10-07 11:02 AM
Until this improvement is done, you can create a directory symlink in your app dir.
