inconsistent designation of registers
pkoevesdi
Senior
In the CubeProg, (for instance) the RCC_D1CCIPR value names (*SRC) are different than in the RM 0433 (*SEL). Such things are a bit annoying, if one tries to find things by a keyword search, of if unsure about "is it really the same entity"? Can someone here pass this to the authors for fixing? Thank You!
pkoevesdi_0-1730451210735.png - CubeProgrammer v2.17.0
pkoevesdi_1-1730451330120.png- RM0433 Rev. 8, p. 496
STTwo-32
Hello @pkoevesdi
Thank you for feedback that has been escalated for correction on one of the future releases of the STM32CubeProgrammer (under internal ticket number 195558 ).
Best Regards.
STTwo-32
2 REPLIES 2
STTwo-32
Hello @pkoevesdi
Best Regards.
STTwo-32
Andrew Neil
Evangelist III
Does this also apply to the names used in the generated source code?
