I get this Error when trying to install the Cube Programmer V2.5.0 on Windows 10(latest update).
I have installed Java jre 1.8.0_261. Thanks for any help
2020-10-08 4:25 PM
com.izforge.izpack.api.exception.IzPackException: An error occured
- in java.lang.Thread.run() at null:-1
- in com.izforge.izpack.installer.unpacker.UnpackerBase.run() at UnpackerBase.java:241
- in com.izforge.izpack.installer.unpacker.UnpackerBase.unpack() at UnpackerBase.java:319
Caused by: com.izforge.izpack.api.exception.InstallerException: File execution failed
- in com.izforge.izpack.installer.unpacker.UnpackerBase.unpack() at UnpackerBase.java:299
- in com.izforge.izpack.installer.unpacker.UnpackerBase.unpack() at UnpackerBase.java:483
- in com.izforge.izpack.installer.unpacker.UnpackerBase.executeFiles() at UnpackerBase.java:959
STM32CubeProgrammer
2020-10-08 6:38 PM
Hello @LBooz.1 ,
Would fail with this error it can be due to the conflicts between Java versions.
So please, if you have many java versions installed try to uninstall all except 1.8.0_26 and then re-install STM32CubeProgrammer.
I'd highly recommend you to run STM32CubeProgrammer using admin rights.
Hope my answer helps you. Please keep me informed about your progress on your issue.
Imen
Imen
2020-10-09 12:28 AM
Hello Imen,
Thanks for the fast reply.
I have only Java jre1.8.0_261 and jdk1.8.0_181 installed. The jdk shouldnt be a problem, right?
I also am admin on my account and in adition tried to execute the installer as admin.
L Booz
2020-10-14 12:57 AM
Hi @LBooz.1 ,
Can you please tell me how do you install Cubeprogrammer? You unzip the install file before? Are you using double click on exe file or command line?
This information are useful to reproduce the issue.
Best regards,
Houda
2021-03-22 6:33 AM
I face the same problem. I unzip the archive file and run the EXE as administrator (win10).
I've tried:
- Different versions from x64 CubeProgrammer: v2.5.0, v2.6.0, v2.7.0.
- Uninstalled every Java installation and installed the latest (jre1.8.0_281) but tried an older one too (jre1.8.0_241). No JDK installed.
- Selected different installation folders
This is the first error screen that pops up, then I get the same Java issue as mentioned above:
x86 version of CubeProgrammer seems to work however.
2021-04-03 1:11 PM
I have exactly the same error message. Tried installing Java 16 and using the 32-bit version using Admin Rights. Didn't make any difference.
2021-05-16 10:58 PM
Hey, is there an update on this I'm seeing the same issue - have tried multiple versions of java and cubeprogrammer
2021-05-17 1:43 AM
Hi @NMurf.1 ,
Are you installing CubeProgrammer with admin rights?
If no can you please install it by clicking right on installer file then "Run as asdministartor"?
Houda
2021-05-17 4:22 AM
Hey Houda, thanks for replying!
Yes I've tried installing it with admin privileges
Cheers,
Nathan
2021-12-17 9:59 PM
Seeing the same issue as described in original post. Trying to install STM32CubeProgrammer v2.9.0 and already have jre1.8.0_311 installed on PC (no other Java installed, Windows 11). I also have the same error window as screen-grabbed by @AVarg.3 and posted above--the window popup doesnt allow me to scroll down to get more information on potential system paths being accessed. Any solutions??
Just in case, I also deleted all ST products and tried to go from scratch but that didn't do anything. I have also been running the installation attempts as administrator.
