Cube Prog API Error write memory
zhoupn
I am using C# to wrap the native CubeProgrammer_API.dll to call download file. I am running on x64 machine.
When I compile the C# code as x86 and use the x86 version of the DLLs from the SDK, the download went fine.
However if I compile the same code as x64 and use the x64 version of the DLLs from the SDK, I am getting a -10 from the downloadfile.
Does anyone know a reason for this puzzling behavior?
Thanks.
Aziz BRIGUI
Hello @zhoupn
Could you share a project demonstrating the issue ? CubeProgrammer API does not provide any C# examples for now. A sample project could simplify things for our teams and other community members.
Thanks in advance
Aziz
