2022-09-29 08:07 AM
I am getting CUBEPROGRAMMER_ERROR_NOT_SUPPORTED (-5) when I try to connect to a device using connectDfuBootloader from STM32CubeProgrammer API v2.7.0. I am logging all the messages I am seeing and I have attached the log to this question. Does anyone know what I'm doing wrong or not doing. The C++ example seems to work fine. I am trying to write a C# application.
2022-10-02 10:02 AM
Hello @MSSloan1962 ,
Please try to use latest release of STM32CubeProgrammer (version 2.11.0), as it contains updates to fix limitations. Then confirm if the problem here still existing with this version.
When your question is answered, please close this topic by choosing Select as Best.
Imen
2022-10-02 10:02 AM
Imen
2022-10-05 01:21 AM
It seems to connect now. I am now using the latest version of the API.
