CubeIDE problems
Hi boys and girls from ST,
I am testing your CubeIDE and it it catastrophe.
1/ I tried to open a new project in CubeID and I ascertained that I can not add assembly file (s). How I can create project with only one file - in assembly. :)
2/ I tried to close my project in CubeIDE, but the project stayed opened. When I tried to run the already closed project the project was compiled and uploaded to my processor vis STLINK :) it is very cute. Is it a special way defence against an enemy ? :)
3/ Did you consider to connect to MS Visual Studio (VS) developper team and use and to develop VS together with MS people instead of your queer CubeIDE ?
4/ Are you planing to completely rework your CubeMX ? For example the "Clock" configuration picture is really terrible. There is no visual connection to individual registers RCC. It it queer chaos.
Jerry
Pavel A.
Have you seen your doctor recently, Mr. Jerry? Do not delay.
JerryMC22Author
I am ok (fully sane) but your product(s) does not work correctly. This is huge problem.
AScha.3
Just to be correct:
- You think, your fully sane.
- (xxx) products not working correctly for you, according to your assessment.
